1995 civic still overheating
my 1995 civic dx d15b7 automatic still is overheating after a new head gasket, water pump, thermostat, timing belt, thermoswitch, and flushed radiator and heater core. What other things could cause this? if you leave the radiator cap off it stays right below half way up on the temp gauge and if you put it on it shoots right to hot in a couple minutes. the fan doesnt come on either. it works if you wire it directly though.
i put the punched out thermostat back on the car that was on it when i got the car and it ran cool. just under half way up on the gauge. and the fans started working after i did this. still has no heat though? i guess it was the thermostat?
Heater not working means that there is air in the system, or the heater core is clogged. When you flushed the core, did water flow through freely? It should be able to handle the full flow of a garden hose.
With no thermostat, the gauge would run at or near cold while the car is moving. With the car stopped it will creep up until the fan starts. If the rest of the system is OK there is no problem with putting a working thermostat in. If you keep driving with no thermostat so the engine is over-cooled, mpg will be lower and the oil will get contaminated.
Take the cap off when it is cold, confirm the radiator is full. Then start and rev the engine with the cap off, if bubbles or coolant blow out, the head gasket is blown.
jald3rd
May 24, 2016 12:11 PM
civic_22
Jun 16, 2008 01:01 PM
