NJ 4/S 1994 civic hatchback $11k
1994 civic hatch, clean NJ title. Asking price $11,000
***Exterior***
-car was just painted pepper grey metallic (Eleanor mustang color)inside out, engine bay, jams, interior, even the inside of the quarter panels is painted and cleared. All done using Glasurit paint and clear. No cheap quality paint here. Car is super clean.
-original quarters, no rot, professionally rolled
-new rear bumper
-new fenders
-new hood
-new Osaka rear wing
-new50/50 tail lights
-new hatch glass shocks and mounts
-welded front and rear emblem holes
-new n1 paint matched mirrors
-new black housing headlights
-new clear corners
-oem front bumper
-first molding rep front lip
-new windshield
-new door window moldings
-new door weatherstripping
-ek side skirts
-new oem mudflaps
***steering and suspension***
-manual subframe conversion
-new rack and pinion
-new tie rods
-98 gsr spindles front and rear
-new bearings out back
-JDM itr brake booster
-JDM itr brake master cyl 1"
-40/40 prop valve
-4 new calipers
-new braided brake lines
-new black anodized drilled slotted rotors
-new emergency brake cables
-new blox rear toe and camber kit
-new function7 rear LCA and brace
-new prothane trailing arm bushings
-new tru hart front camber kit
-new front lower control arms
-ebay traction bar setup with upgraded hime joints
-BWR one piece suspension
***wheels***
-16x8 et20 Rota Grid
-Rays stickers and center caps
-Rays lug nuts
-federal 595 r tires
***engine***
-Usdm GSR engine with papers
-jdm gsr trans
-ACT flywheel
-comp stage 3.5 clutch kit
-billet shifter bushings
-engine was a running high mileage engine/never blown
-deglazed cylinders
-polished crank
-decked
-eagle rods
-wiseco 10:1 Pistons
-ACL race bearings and thrusts
-ACL high vol oil pump
-All oem gaskets
-Moroso oil pan
-milled cylinder head
-ported intake and exhaust
-5 angle valve seats
-ferrea 6000 series valves
-supertech HD valve springs
-supertech retainers
-supertech valve seals
-GSC T1 cams (degree'd)
-toda cam gears
-ARP headstuds
-Edelbrock victor X intake manifold
-70mm Omni throttle body
-AEM rail and regulator
-Aeromotive 340LPH fuel pump
-South bay 1000cc injectors
-Full race ram horn manifold
-precision 6262 w/ billet wheel
-Tial 44mm wastegate
-Tial rep 50mm Bov
-mishimoto black intercooler
-3" V-band downpipe to side dump exhaust in front of passanger rear wheel
-4bar map sensor
-Mac boost solenoid
-All boost/vacuum connections done in stainless tubing
-hondata s300 with boost option
-Wireworx engine harness with bulkhead plate
-engine bay harness tucked
-Odyssey pc680 battery
-Glowshift boost,wideband, and oil pressure gauges.
-Personal 330mm steering wheel with NRG quick release and lock.
***im forgetting a ton of stuff but it's all there.
Just under 300 miles since rebuild, no smoke, no leaks, no strange noises...
I will be getting it dyno tuned on Tuesday by CLM racing.
I will post dyno results.
Zico@zicodidit.com or text me at
908-372-8068
Yea... I couldn't find real rays rims in this offset. And I live in NJ, where pot holes are plentiful. I'd rather bend one of these and just replace it than bend a rays rim and have that ruin my week, or quite possibly my month...
Thanks! I love the car but I'm in between buying a house and selling mine. Need to free up some cash to make sure the process goes smoothly.
drshottest718
Nov 14, 2006 04:20 PM
