Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic Sputter
Old Apr 7, 2017 | 08:27 PM
landoncholt's Avatar
Default 2001 Honda Civic Sputter
My car started sputtering while driving, so I changed out the spark plugs and it didn't fix the issue. I then changed out all 4 ignition coils, and it still sputters.
Not sure what other options I have, please advise.
- Landon
Old Apr 7, 2017 | 09:02 PM
bbarbulo's Avatar
Default Re: 2001 Honda Civic Sputter
bit wasteful on swapping parts without testing them, at least the coils. hope you kept the old ones, OEM is king!
valve lash being out will cause misfiring, plugged fuel filter, plugged air filter, bad coolant temp sensor, bad intake air temp sensor, etc...
does it do it cold, warmed up, under load, under no load, closed/open loop, etc...
any codes come up/check engine light flashing or on solid?
Caventi
Mar 29, 2017 12:14 AM
williamscc
Jan 26, 2012 11:44 AM
jballerz23
Oct 6, 2009 03:01 PM
scottc76
14
Jan 2, 2009 02:54 PM
Sonny
Feb 6, 2006 04:33 PM
