d15b long blocks, any difference between injected and carby?
Old Apr 7, 2017 | 08:07 PM
ThatGinjaDude's Avatar
Default d15b long blocks, any difference between injected and carby?
so my mate's bought me a crash damaged eg with an injected d15 and another tidy eg with rod knock and a carby d15. I understand the complexities of converting carby to injected and I very much want to avoid those problems, so am i able to swap the long block and leave the tidy one as a carby? will the manifolds etc match up?
Old Apr 7, 2017 | 09:38 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: d16b long blocks, any difference between injected and carby?
Is your injected D15B a vtec unit?
Old Apr 7, 2017 | 09:39 PM
mk378's Avatar
Default Re: d15b long blocks, any difference between injected and carby?
Yes you can swap just the engine and bolt on either kind of intake. Most injected engines do not have a place to mount the mechanical fuel pump though.
Old Apr 8, 2017 | 01:00 AM
no, both non vtec
Old Apr 8, 2017 | 01:02 AM
you can get low pressure electric fuel pumps for carby motors can't you? any idea what pressure I'd need?
Old Apr 8, 2017 | 04:12 AM
94EG8's Avatar
Seagull Management
The short block is the same. The head is different in terms of the carbed version having a place to mount the mechanical fuel pump (the fuel injected heads are cast with the mounting bosses, but you would have to cut out part of the head, it's do-able, but you'd have to take the head off to flush the chips out) and the cam is different (extra lobe to drive the mechanical fuel pump) you can either run a low pressure electric fuel pump, swap heads, or modify the head on the fuel injected engine and swap the cam.
Old Apr 8, 2017 | 05:12 AM
mk378's Avatar
Yes. The pressure is not critical, they are usually about 5 psi. Just don't use a high pressure fuel injection pump.
Diyracing2
Jan 29, 2007 10:40 AM
kornerk12
Oct 15, 2006 03:58 PM
cherroneballs
Mar 19, 2005 09:40 AM
t04ef
Jan 26, 2002 10:49 AM
