d15b long blocks, any difference between injected and carby?
so my mate's bought me a crash damaged eg with an injected d15 and another tidy eg with rod knock and a carby d15. I understand the complexities of converting carby to injected and I very much want to avoid those problems, so am i able to swap the long block and leave the tidy one as a carby? will the manifolds etc match up?
Re: d16b long blocks, any difference between injected and carby?
Is your injected D15B a vtec unit?
Re: d15b long blocks, any difference between injected and carby?
Yes you can swap just the engine and bolt on either kind of intake. Most injected engines do not have a place to mount the mechanical fuel pump though.
you can get low pressure electric fuel pumps for carby motors can't you? any idea what pressure I'd need?
Seagull Management
The short block is the same. The head is different in terms of the carbed version having a place to mount the mechanical fuel pump (the fuel injected heads are cast with the mounting bosses, but you would have to cut out part of the head, it's do-able, but you'd have to take the head off to flush the chips out) and the cam is different (extra lobe to drive the mechanical fuel pump) you can either run a low pressure electric fuel pump, swap heads, or modify the head on the fuel injected engine and swap the cam.
