Vacuum leak?
If I rev the car up and let off the throttle the rpm goes to normal idle but then goes a bit up and then goes back to normal idle and stay that way
already checked IACV and cleaned it, Also changed for a different one but still the same..
So could It be a vacuum leak?
Engine is a D15Z6 vtec-e
"This video is not available."
Does the car drive OK? If so, I wouldn't pay much attention to exactly what happens when revving up in neutral.
The VTEC-E engine found in the 1992-95 VX is D15Z1. D16Z6 is the regular VTEC used in the EX.
It's kinda annoying because I get the same thing when I drive around and kick the clutch in.... and at traffic signs..
car runs great only.. nothing weird..
https://youtu.be/Am98D-zg69I
maybe you can check it now?
ejvtec
Jan 24, 2010 02:27 PM
2a5x1
Nov 28, 2008 03:37 PM
dark-b16a1
Sep 26, 2006 10:33 AM
