No dash lights or guages
Old Apr 3, 2017 | 08:27 AM
HondaRookieMech's Avatar
Default No dash lights or guages
I just replaced my F23A engine with another JDM F23A engine. These were virtually identical everything including the components. The only things I swapped were the throttle body, some hoses, brackets, the reverse sensor in the tranny and I changed all of the fluids. It started and ran just fine on the first attempt. But now there are no indicator lights on when I turn the key to the second position. Also when the engine is running I have no tach, speedo, temp indicator or power windows. I also am getting a fairly high idle speed of about 2500 rpm. There may be a few other things out of whack that I haven't noticed. But the other accessories seem to work. I have checked all of the fuses, grounds, plugs and sensors. They all seem to be good. I had another alternator which had been tested good so I swapped that one out also.
Joka74
15
Jun 10, 2014 10:35 AM
Steve02
Nov 25, 2007 02:01 PM
93hatchdude
Aug 28, 2007 09:11 PM
ttutor
Aug 15, 2007 10:40 AM
