Need your help guys with 92 Integra 1.8
So I bought this 92 Integra this past Monday. I test drove it and it was fine. My friend helped me drive it home and he said it was fine. The next morning I let it warm up and take off to go to work. It dies on me when coming up to the first stop light. I try re-starting it multiple times and nothing. 5 minutes later it starts up and I go to work 30 min away with no problems. As I'm leaving work the same thing happens to me before I even leave the employee parking lot. This time it doesn't start withing 5 min so a few coworkers help me push it back into the parking lot. It starts up again after 10 min so i start heading home. Everything is fine until i get off the freeway. Almost at every red light the engine dies or almost dies, but I'm still able to re-start the engine. Sometimes I get no response from the engine when I give it a couple of revs. The next day it just will not start anymore. I already replaced the main relay and distributor and still nothing. I'm getting fuel and spark, but the spark looks low. Have any of you had this problem and what did you do to fix the problem? Thanks
Could be an issue with the idle air control. I'd peek at that. I've had issues with both my Civic and Teg with that getting clogged and dropping my idle as well as my throttle body becoming built up with carbon and restricting air flow.
Thanks LadyCamouflage, but it ended up being a bad fuel sending unit. The gauge was showing 1/2 a tank when it really had nothing in it. I knew it was something stupid.
paceman
Jan 14, 2008 11:57 AM
