1990 Ef auto to manual help
Old Mar 31, 2017 | 06:23 AM
Blueman5624's Avatar
Default 1990 Ef auto to manual help
hey guys been a while since I posted on here. But I'm stuck I just swapped out a whole motor a d16a6 auto to a complete d15b7 manual into my 1990 ef civic sedan ex . the motor has the same intake as the stock obd0 one on the car so il assuming it's already obd0 injectors and dizzy but anyways I did all the wiring I needed. I connected the 2 black wires down by the shifter and removes the blue box under the seat to remove The key. I tried to used both engine harnesses with the motor, everything plugs in fine and I also tried using the auto ecu and pm6 ecu still won't fire up the timing is good cause I pulled the motor from a car I drove home.. My problem is doesn't want to fire and if it does it's off like 2 cylinders. the car started up fine before I did anything , all cylinders just the motor was shot. If anyone can send me some pointers or in a direction much apprciated
getzy3
Jan 7, 2016 03:24 PM
_gee
Sep 24, 2014 10:23 AM
phirewire
Jan 29, 2012 09:59 AM
Shonda
Apr 13, 2006 05:29 AM
ssdjoey1904
Sep 12, 2005 05:53 PM
