96 gsr b20b no spark
my clutch switch broke the plastic piece off so i fixed them cruise control and the one on the.clutch after that my car wouldnt start . It died a few times but started.right back up =/ im getting.compression my timing is fine also . my fuel pump is now toggled .... i need help
Well first of all, if you have trouble with the switch on the clutch, it could be most of your problem. That's your "neutral safety switch". Perhaps it needs adjusting, or it's sticking. Maybe just needs to be replaced. Also, does your check engine light turn off? If it stays solid when u turn the key, your ECU is bad. I'd also double and triple check all your fuses. I've actually seen a bad fuse that was barely burned, and actually appeared OK!
Nikki Aulicino
Jan 26, 2017 10:25 PM
MShonda
Apr 5, 2013 04:44 AM
thefryer
May 6, 2012 01:14 PM
zerovandez
Apr 1, 2011 01:05 PM
