Honda Accord 2004 driver door open switch broken.
You might have more luck posting this in the accord forum.
If it's the same style switch as in the EF's though (switch grounds when door is open), then you could simply unscrew the switch from the jam and remove the single wire plug from the back of it. This will make the circuit assume the door is always closed.
Better yet you may be able to see why the switch is incorrectly grounding with the door closed. Or just grab another from a wrecker and replace it.
