Hasport dx to SiR wiring
Old Nov 9, 2002 | 09:12 PM
B17EF's Avatar
Default Hasport dx to SiR wiring
I had Hasport make a conversion harness from my dx and b17 wiring, but can't figure out which wires are which. There are 7 wires being added at the ecu. I know that 4 are those necessary for vtec function, but what are the other three? Does anyone know if they usually retain factory wire color coding? I wnder if I could figure it out that way.
Old Nov 9, 2002 | 09:22 PM
MADEINIRAQ's Avatar
Default Re: Hasport dx to SiR wiring (B17EF)
call hasport
Old Nov 9, 2002 | 09:33 PM
Aphrodavid's Avatar
Default Re: Hasport dx to SiR wiring (madeiniraq)
call hasport
exactly, if hasport made that harness for you, theyre obligated to help you.
Old Nov 9, 2002 | 09:37 PM
B17EF's Avatar
Default Re: Hasport dx to SiR wiring (Braveheezy)
Yeah, but they aren't open until monday and thats when I go back to work. I'm sure they could easily clarify though
Old Nov 9, 2002 | 09:40 PM
MADEINIRAQ's Avatar
do you have the directions?
http://www.hasport.com/Tech/Wring/Dx...r%20wiring.PDF
whatever you do.. don't get your conversion harness mixed up with rewiring your harness. since the two methods take slightly different approaches to converting to multiport.
i mean.. don't use the wrong directions..
good luck
chadmasterc
Jul 9, 2003 07:43 AM
2ndGenREX
May 27, 2003 06:22 PM
redsin
10
Jan 22, 2003 03:14 AM
internet ay
Aug 5, 2002 07:56 PM
90_Civic_Hatch
13
Jun 11, 2002 12:52 PM
