Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
OBD Code P0460 in Honda civic 2003
Old Mar 28, 2017 | 07:05 AM
Walkingincirkle's Avatar
Default OBD Code P0460 in Honda civic 2003
The light showing showing emission sensor malfunction came on. I checked the code. It showed P0460 (bank #1). I do not notice anything wrong in the motor performance, except sometime during acceleration I can smell gasoline. what should I check first to diagnose exact point of the problem?
Old Apr 29, 2017 | 08:55 AM
Mike Gibson's Avatar
Default Re: OBD Code P0460 in Honda civic 2003
P0460 is for the fuel level sender. You'll probably need a new sender/fuel pump. I'm pretty certain it's unrelated to the fuel smell, though. Find that fuel leak. Not good mojo in a hot engine compartment.
Old May 7, 2017 | 09:46 PM
prodjay10's Avatar
I've had the top of the fuel pump of both my civics crack which caused the inside of the car to smell like gas. I did not have that code.
Jahmani
Nov 9, 2018 03:53 PM
elflako
Jun 19, 2009 07:36 AM
95civic16
May 18, 2009 08:01 PM
89 CRX SI
Apr 22, 2003 03:22 PM
