Transmission & Drivetrain Gearboxes, Differentials, Clutches
K20 & K24 transmission suggestion
Old Mar 27, 2017 | 08:16 AM
lolv8s's Avatar
10 Year Member
Default K20 & K24 transmission suggestion
ok I have a 2006 Civic Si coupe and my transmission either needs to be rebuilt or swapped. I think the most cost efficient and time saving way to do this is just to swap the transmission. I saw a K24 standard Accord in a junkyard the other day and thought about getting the transmission. But I thought about how it wouldn't have an LSD and aggressive gears as the Si. But could the LSD and gearing be swapped? (except the 5th gear) for cruising speed. What do you guys think? I know I would be putting a 5spd transmission into a 6spd car. My 4th gear grinds. But I think that would be the syncro. I have never worked on transmissions besides changing the fluid/ clutch/ and flywheel. So I thought I'd ask. Thanks!
Old Mar 27, 2017 | 12:59 PM
Aquafina's Avatar
Default Re: K20 & K24 transmission suggestion
Fixing your transmission will be easier than swapping the internals into another case and fixing it.
With a grind, be prepared to replace the synchro, slider, hub, gear and shift fork.
Old Mar 27, 2017 | 09:33 PM
lolv8s's Avatar
10 Year Member
should I buy an entire syncrotech rebuild kit? or could I maybe get away with just the synchro kit?
Old Mar 28, 2017 | 08:47 AM
Aquafina's Avatar
I would open the transmission up first before ordering. If time is an issue though then I would order a master rebuild kit plus a mainshaft 4th gear from Honda. You can shoot me a PM to order any Synchrotech parts.
lolv8s
Honda Civic (2006 - 2015)
Mar 28, 2017 05:35 AM
JRCivic1
Jan 25, 2017 09:28 PM
Keenor
Apr 21, 2011 02:21 PM
sk8shorty012
15
Nov 20, 2010 11:27 AM
PupaScoopa
Apr 8, 2003 10:01 AM
