92 Accord TCM code 14
Old Mar 23, 2017 | 08:10 PM
klf650's Avatar
Default 92 Accord TCM code 14
Check engine light is on solid. Transmission is not shifting correctly. Engine misses out after 3500 RPM. Checked the codes TCM code is 14. Tested transmission solenoids . Solenoids tested 14-15 ohms. Checked solenoids with voltage. Solenoids appeared to be operating correctly. Any body have any suggestions.
Old Mar 27, 2017 | 01:07 PM
Nealva's Avatar
Default Re: 92 Accord TCM code 14
See this thread. Mine turned out to be wet carpet on the passenger side which was apparently causing a circuit issue between the ECU and ATCU or TCM
https://honda-tech.com/forums/honda-...codes-3289102/
Tyrell Bivens
Jul 31, 2015 02:46 PM
larryw1945
Sep 30, 2013 11:21 AM
