Help! Koni/GC install with GC extended tophats
Old Mar 23, 2017 | 06:34 PM
petr0lb0mb's Avatar
Default Help! Koni/GC install with GC extended tophats
Looking at the picture, is this the correct order of assembly? I'm not running dust boots, because I can't see how they could be installed with the extended tophats.
Since I'm not running a dustboot, I was just going to use the thicker washer and leave the larger/thinner washer out.
I'm, also leaving out the metal tube because I don't think I'm supposed to use it in this case. If anyone could confirm that this is the right configuration or correct me if not, I would greatly appreciate it.
Old Mar 23, 2017 | 09:20 PM
petr0lb0mb's Avatar
Default Re: Help! Koni/GC install with GC extended tophats
And what are these O-rings included for?
.I.Need.Money.
Suspension & Brakes
Feb 9, 2007 01:44 PM
rasta420
20
Jan 25, 2004 11:40 PM
yangrou8
Jul 29, 2003 09:05 AM
Sportmode
Jun 5, 2003 04:57 PM
