Squeaking noise, lend me your ear honda-tech.
Old Mar 20, 2017 | 02:42 PM
middernachtklub's Avatar
Default Squeaking noise, lend me your ear honda-tech.
Long time lurker, who fixed many a problem with the information on here. Sadly, can't find anything that fits the bill for this. So hoping anyone of you might make an educated guess.
The sound is there only from around ~1000-1100 rpm.Can't exactly locate it but what is filmed seems to be the general area. Not sure if it's a belt noise. Seems to chug a bit and isn't that constant. Belts look okay, sprayed them down to no effect. In hindsight not have been able to reach the ones down in the engine bay properly. If I can say for sure it isn't a belt will try to locate the sound with an automotive stethoscope. In the mean time, someone here might exactly know what it is and prevent me from going on this wild goose chase.
EK3 97'
73k miles,manual D15Z6 (EUDM).
Old Mar 20, 2017 | 06:11 PM
mk378's Avatar
Default Re: Squeaking noise, lend me your ear honda-tech.
Sounds kind of like power steering pump running dry. Is the P/S fluid full? Use only Honda or Honda compatible fluid to top up. Most generic fluids will damage the steering system.
Using about a 3 foot length of hose (old garden hose) holding one end to your ear while you move the other end near possibly noisy parts is a good way to localize noises. Be very careful of moving parts of course.
Take all 3 belts off, spin the parts by hand see if any are noisy. Start engine with belts off; if the noise is still there you will need to check the water pump and timing belt tensioner under the cover. Has timing belt service ever been done?
Old Mar 26, 2017 | 04:19 AM
All fluids are level, timing belt is well within spec. Did a visual inspection but it looked solid. Changed out the power steering, brake and clutch fluid because they were very off colour. To no effect, other than peace of mind. Did a rummage around with an automotive stethoscope but couldn't localize it.
I'll have a go with the belts off. Will report back. Thanks for your help.
Old Mar 28, 2017 | 01:40 AM
Small update,
Tracked it down to the alternator - still unsure whether it's a bearing, pulley or the belt. Treated the belt with belt dressing and the noise reduced and became more intermittent, but didn't go away.
Old Mar 28, 2017 | 04:28 AM
civic402lx's Avatar
Take the belt off. Spin the pulley. If it catches, it may be going. New belt is less then $10. You need new one anyway, replace it.
guille595
Jan 27, 2026 08:46 AM
Brett Curtis
Jun 13, 2016 03:29 PM
mkrieger500
Nov 21, 2010 12:09 AM
es_squared
Aug 22, 2004 09:19 PM
AggAccord03
Jan 11, 2002 03:49 AM
