1994 INTEGRA LS
so my car was stollen when i got it back goto start it and it would just rev to 4000 and stay looked under the hood it looks like the tps sensor was un plugged, i plugged it in and now its surges from 4000 to 1500
Try to reset the ecu. On my 92, it's the back up light fuse, under the hood. The ecu fuse ( on my car) won't reset it. Other than that, the whole system (crank angle sensor, timing advance, ignition module) are all part of the distributor. Id also recommend adjusting the ignition timing if u can get a solid idle. I also know, that if the pcv valve is damaged or disconnected, the idle will not be steady.
jorge59la
May 18, 2007 06:18 PM
