civic idle issues
Old Mar 18, 2017 | 09:08 PM
todd j's Avatar
Default civic idle issues
Throwing a po505 code on my 99 civic. Only has trouble after it warms up. Idles fine till I push gas pedal just a lil bit. Then it start stuttering. Car is in park
Old Mar 19, 2017 | 05:26 AM
Jimi Hondrix's Avatar
Default Re: civic idle issues
Remove and clean throttle body and IACV valve. Replace IAVC valve gasket (flattens, stiffens and leaks).
Old Mar 19, 2017 | 05:51 AM
todd j's Avatar
Thanks. IACV is brand new from ebay but I will clean the TB today and replace all gaskets if anybody has them on a Sunday...Thanks again
Old Mar 19, 2017 | 06:59 AM
Is it an OE/OEM part? If not, that could possibly cause a problem as well.
Old Mar 19, 2017 | 03:27 PM
todd j's Avatar
No it was an aftermarket IACV...Should I put the old one back on to see what it does. Have to wait till tomorrow anyway to get some IACV gaskets
Old Mar 19, 2017 | 06:07 PM
Did you do an ECU reset after replacing the IACV?
You can try cleaning the inside of the old one with brake cleaner (shown in video), I'm not saying the aftermarket one that you purchased won't work but, these engines can be finicky with aftermarket parts.You may want to spray the IACV connector and wiring harness connector with DeOxit or similar electronic cleaner and lube. Also, inspect IACV wiring harness with your fingers to look for a possible break in the wires.
IAVC cleaning:
Old Mar 19, 2017 | 10:21 PM
todd j's Avatar
I will do all those things Monday night after I pick up a few sets of gaskets from honda and some contact cleaner and grease...Thanks again for all your help
Old Mar 19, 2017 | 10:56 PM
todd j's Avatar
And just checking...ECU reset is done by unhooking the battery and touching the terminals together for about an hour....Correct or no...Thanks
Old Mar 20, 2017 | 07:50 PM
That should work but, I do mine like this:
1) Disconnect negative terminal from battery.
2) Turn headlights on and press brake pedal a few times (discharges residual current)
3) Reconnect negative terminal
4) Turn off all electronics (lights, stereo, windows, a/c, etc.)
5) Start engine and let idle for 15 minutes .(keep elctronics off)
6) Shut off engine
Old Mar 21, 2017 | 04:47 AM
mk378's Avatar
You don't have to wait an hour. A few seconds is sufficient. Pulling the "BACK UP" fuse under the hood also works to cut power to the ECU memory, but that still causes the radio to be reset, so there isn't an advantage over disconnecting the battery.
Old Mar 21, 2017 | 09:03 AM
Mugen_freak_si's Avatar
I have the EJ6 99 civic dx with the d16y7 1.6l sohc non-vtec. I am a first time civic owner. I have some idle or engine shutter and shake issues. Brief description I start it up runs fine but as i apply the brake to slow down at almost idle or right before it vibrates my whole car for 30-40 secs. then stops. Any thoughts Ideas and what to do to fix it or any links. I'd appreciate any help as this is my daily driver. Im no master mechanic and def not a honda expert but i work on my own stuff and the more i can learn the better.
Old Mar 21, 2017 | 11:27 AM
Start a new thread. Don't hijack current one.
Old Mar 21, 2017 | 04:53 PM
todd j's Avatar
Well I'm on hold for a few days...Had to order IACV gaskets from Honda and wont be here till Thursday...I will let you know what happens when I put it back together....Thanks again for all your help.
Old Mar 22, 2017 | 04:58 AM
Hopefully, you'll get it sorted out soon.
Old Mar 24, 2017 | 08:57 PM
todd j's Avatar
So far so good...No PO505 code. Does this have to be driven 50-100 miles since I reset the ECU or no....Thanks
Old Mar 25, 2017 | 02:41 AM
If it the CEL doesn't comeback within a week or so of driving you should be good.
Old Mar 25, 2017 | 04:50 AM
todd j's Avatar
I drove it about 10 miles last night and no CEL...Do you think it would be ok to do a CA smog check today or No...Thanks
Old Mar 25, 2017 | 11:17 AM
710times's Avatar
you have to drive at least 40 miles for all the monitors to be ready or youll go down to smog it and theyll say its not ready yet. i would drive at least 60 miles with shutting the engine off and on at least 2 times to cycle the ecu. but as long as you do all that and no cel youll be good. i just did my smog a few weeks ago. here in imperial ca you only smog everytime you change owners. if you go down there so smog it without putting some miles on it their gonna know you just cleared the codes. since the monitors are not yet ready
Old Mar 28, 2017 | 03:23 PM
todd j's Avatar
Seems like everything worked...I ended up cleaning the TB and the IACV but put the new electronics on the old IACV and reset the ECU...No codes and it passed CA smog...Thanks to Jimi Hondrix for all his help...Thanks again. Car runs great and the smog tech said it passed by a lot and was running very clean...
Old Mar 28, 2017 | 04:06 PM
JessumYessum
May 7, 2015 04:04 PM
schpiel
16
Jul 25, 2012 05:21 PM
ezeedude
16
Feb 26, 2008 12:06 PM
ITRacer121
11
Mar 25, 2005 01:49 PM
caLiH22A
Aug 24, 2004 08:05 PM
