coil pack and sparks plugs
Old Mar 17, 2017 | 01:52 PM
wanda robinson's Avatar
Default coil pack and sparks plugs
just puy on 6 coil packs and change the sparks plugs on 2002 honda accord v6 and it's still miss fire what can be the problem.
Old Mar 18, 2017 | 08:25 AM
GhostAccord's Avatar
Default Re: coil pack and sparks plugs
A misfire can also be caused buy issues with the fuel system or the health of the engine cylinders, lack of compression. Are you getting a check engine light, if you are, what code are you getting? P0300, P0301, P0302.....etc etc. If you are able to scan the computer and retrieve any codes they may be able to point you in the right direction.
If you do not see a check engine light, nor have any diagnostic codes. Then the next step would be to do a compression test on each cylinder and also test your fuel pressure, fuel injector operation.
K-G
Sep 14, 2019 10:36 AM
lucidojj
Mar 16, 2015 07:11 AM
Tucker33
Dec 16, 2013 09:40 AM
Robin1955
Engine Management and Tuning
Nov 9, 2013 06:59 AM
AllMotorDan
15
Dec 23, 2006 05:57 AM
