injector question
No idea. I believe the only difference is weather or not you need the resistor box. BTW: You can still find brand new OEM CRX injectors (made by Keihin) on e-bay (or other places) in a Bosch box. I think the part# is 4920565, but please verify 1st.
runs fine is not the same as runs right. d15b7 is obd1 so you still need to remove the resistor box. saturated injectors are considered better than peak/hold injectors, so nothing wrong with using OBD1 injectors. just the resistor box has to go.
Randysi
Apr 4, 2012 10:17 AM
pinecone
Apr 25, 2006 06:41 AM
