Have a problem with a friend B18c 12.6cr pro2 camshaft
90 pump with 15% ethanol mixture and tuned with HONDATA
here is the problem
just one piston damage
why is that happens ? What the problem come from ?
car tuned on 13 AFR @ Low cam and ~12.8 12.9 AFR @ WOT
Spark plugs used Side view of the damaged piston Top view of the same piston Otherside view of the same piston
Yeah best power on dyno..but on the street the engine is more in stress on load. More knock...which ignition do u run and which spark plugs and which gap?
