2000 Accord - Limp mode - Crank sensor code.
Old Mar 12, 2017 | 05:48 PM
tyree ruffin's Avatar
Default 2000 Accord - Limp mode - Crank sensor code.
My 2000 honda accord is in limp mode....I got a code for tdc sensor (crank sensor) replaced it, same code came back, replaced my distributor still in limp mode any other suggestions???
Old Mar 13, 2017 | 12:10 AM
holmesnmanny's Avatar
Default Re: 2000 Accord - Limp mode - Crank sensor code.
You need to test from the crank sensor connector itself. Here's a sample test I found off the internet. http://www.civicforums.com/forums/36...on-sensor.html
You also need to make sure the crank timing pulley and balance shaft pulleys are both nice and clean which is where the tdc and crank sensors test off of.
Old Mar 15, 2018 | 11:11 AM
animaul22's Avatar
I did all that too, and still get the same problem p1361. Seems to only trip once car is warmed up. If you found out what it was pls post!!!
Old Mar 15, 2018 | 10:35 PM
You need to test from the crank sensor and tdc sensor to the pins at the ecu connector. If you got continuity all the way back at both pins then it's likely the ecu is bad.
.:FFS TechNet : OBD2a ECU Pin out Schematics :.
civic1999si
Nov 2, 2019 06:25 PM
Keno Smith
Nov 5, 2012 10:56 AM
YAH YAH
Dec 7, 2008 06:19 PM
CHAZegHATCH
Jul 20, 2006 06:33 PM
