Blowing white/blue smoke from stoplight.
Old Mar 12, 2017 | 02:07 PM
Legacy75's Avatar
Default Blowing white/blue smoke from stoplight.
Car: 88 Civic Hatch DX Auto. Stock 1.5L sohc. So my car only smokes from a stoplight in first gear while warmed up. Car is not overheating. Coolant is good. Oil is good not milky or anything. Not burning any oil either. I do think it smells like oil when it happens though. I check the oil periodically and it stays level. Any help would be appreciated, Thanks.
Old Mar 12, 2017 | 04:17 PM
got_no_sol's Avatar
Default Re: Blowing white/blue smoke from stoplight.
White is water (sometimes running slightly rich will spear as white or gray just smell it you can smell burnt antifreeze , blue is oil straight up , generally if it smokes at idle it's valve seals if it smokes under acceleration /load it's rings , sounds like you might need a head gasket and valve seals to me
Old Mar 12, 2017 | 11:24 PM
bbarbulo's Avatar
compression test compared with oil-backed compression test. will tell you if rings are the issue.
codyweiss97
Mar 8, 2014 11:04 AM
hadden
11
Aug 7, 2013 10:57 AM
blackmfoggie
Sep 7, 2007 07:34 PM
egdriver94
12
Aug 20, 2006 07:21 PM
SixPAK
Jun 3, 2003 12:28 PM
