Suspension Set-up
I'm planning on purchasing the following at the end of this month:
-Ground Control Coilovers
-Tokico Blue Shocks
-Neuspeed Upper Strut Tie Bar
-Neuspeed Rear Tie Bar
-Neuspeed Front Lower Tie Bar
-Neuspeed Rear Lower Tie Bar
-Neuspeed Rear Sway Bar
-Integra GSR Front and Rear Brakes
I was just curious if anyone was using a set up like that or similar to it? Please let me know how it is. Also, if anyone can suggest some good new control arms, I'd like to get some of those too. Thanks
-Tokico Blue Shocks
Make sure you get adjustable shocks. Everyone I know with non-adjustable complains about the ride. As for the rear strut bar (that goes in the trunk) it doesn't do ****! Well,
Except for make you cut your carpet and lose trunk space. As for the control arms, I would suggest getting an Ingalls or Neuspeed camber kit. The hatch doesn't require control arm replacement. Hope this helps!
I would forego the lower tie bars and spend the money on some better shocks. The Tokico blues are a good replacement if you just want to replace worn out factory shocks, but they're not very competition oriented. I think the average price for the Tok blues are about $80ea. Fork over the extra $'s and go with Koni yellows with some decent springs. Ground Controls are good (I think they come with Eibach ERS's) with 12Kg front and 8Kg rear -- whaetver that translates into emperial measurements.
bluebomber
Mar 2, 2008 12:32 PM
JDMCRX
Apr 12, 2004 12:21 PM
Draggin99Si
20
Feb 5, 2003 07:10 AM
