96-00 civic b20b swap want to keep power steering
Old Mar 11, 2017 | 04:41 AM
KiNGDEE206's Avatar
Default 96-00 civic b20b swap want to keep power steering
i read the FAQ keep in mind I've never had a stock b with ps ac
i have a dd a dd which is 96 dx civic
swapped with high comp 99/00 b20b
i only want ps
do not care for ac
now do I just buy a crv 97-01 bracket upper bracket I see them on eBay for 40 bucks
and bolt it on and voila?? With my d series pumpstuff
or do I need the lower bracket too or no aka mandatory to get lower plus upper bracket just to keep ps?? From 97-01 crv only bc its b20b
Old Mar 11, 2017 | 01:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 96-00 civic b20b swap want to keep power steering
The CRV P/S bracket is one piece... there is no upper and lower bracket combination like on a B18A/B or B16A/B, B18C1/5 etc. The part number is 56997-P3F-000 on the 1997-2000 CRV model. The advantage to using this OE part is that the '96-00 Civic P/S pump and the CRV P/S pump are very similar in how they mount, so you can keep the P/S parts already on the car.
Old Mar 11, 2017 | 02:22 PM
eh2_Trav's Avatar
I have one if you want to buy a CRV P/S bracket.
Old Mar 11, 2017 | 03:58 PM
KiNGDEE206's Avatar
check inbox asap
Old Mar 11, 2017 | 07:30 PM
94EG8's Avatar
Seagull Management
CR-V pump and bracket definitely works, I've personally done this, the lines fit perfectly.
'94 - '01 Integra LS brackets should work with the stock pump or a '98 - '01 Integra pump ('94 - '97 Integra pump has different fittings and the '96 - '00 Civic lines wont fit)
sportsman1539
Oct 14, 2014 06:32 PM
Kidnkorner
Jan 22, 2011 06:25 PM
denracho
Nov 6, 2009 07:37 PM
fortillian
Sep 27, 2009 07:04 PM
93civiconair
Mar 17, 2005 08:12 PM
