Honda CR-V & Element 2WD & 4WD Element & CR-V
05 CRV Kraftwerks Supercharger A/C problem.
Old Mar 10, 2017 | 09:22 PM
hehu's Avatar
Icon5 05 CRV Kraftwerks Supercharger A/C problem.
I have 05 CRV with a used engine 60k mile my old one overheated. im think about putting in Kraftwerks Supercharger kit. i know it fit in my car but Kraftwerks says Kit REQUIRES removal of A/C Compressor. i live in the south is heat here. i like to get so more info before buying this kit. i did some sending and people got it to work on accords, civic si, tsx, tl, rsx with the k24 or k20 engine and there a/c works. but they dont tell me how they got it to work. i just dont know why i need to remove my a/c compressor. i talked with the salesman he dont know nothing. hope someone here did this before.
Old Mar 12, 2017 | 10:03 PM
SadBurro's Avatar
Default Re: 05 CRV Kraftwerks Supercharger A/C problem.
Don't know anything about it but I do know that you might have some troubles figuring out a tuning solution. If you have a manual and PPA ecu then you could use Kpro I believe. Best of luck. A supercharger would be awesome though.
Old Mar 13, 2017 | 05:54 AM
tony_2018's Avatar
Fish Twig
Go with a different supercharger setup, your only option.
Old Mar 14, 2017 | 02:57 PM
hehu's Avatar
Kraftwerks Supercharger is very reliable and get good gain for the money. but im open minded what are other some s/c kits will fit in my car? i have been looking for about 2 year now. i got a new motor inside running strong with no problem its the time now. i love my crv is my DD and my work car.
Old Mar 14, 2017 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There are two different applications from Kraftwerks that are designed to be installed on the "K" series engine platform... one places it where the A/C compressor originally resides and the second is up high above the alternator and water pump where a conventional P/S pump might be found. If you currently have a conventional style P/S pump, it could be replaced with an electric P/S pump... and thus, making room for the Kraftwerks supercharger system and still RETAIN the A/C compressor for those hot southern summer days. You didn't answer the question about the transmission in the vehicle... if it is an automatic, you will have a very difficult time providing the proper tune for the vehicle and the powertrain as a whole. There is no "kit" that is complete for your application... you will have to blaze the trail and CREATE a whole lot to succeed with this path. Good luck.
Old Mar 15, 2017 | 05:11 AM
tony_2018's Avatar
Fish Twig
For some reason I was thinking of the Honda Fit kraftwerks supercharger, it fits behind the block, darn....
Old Mar 15, 2017 | 10:09 AM
hehu's Avatar
omg i never think of that. thanks a lot. i need to do same sending now. my crv is a auto. i just like some low rpm power. im not planing to race it and hit top end power.
hehu
Mar 13, 2017 07:31 AM
RACEPAK
Honda Civic (2006 - 2015)
Feb 14, 2016 03:02 PM
Tyson
Honda Insight & CR-Z Hybrid
54
Aug 3, 2012 01:35 PM
B33R
Honda S2000
Feb 17, 2007 11:09 AM
SI_DRIVR
Dec 21, 2003 06:59 PM
