FS: Powdercoated K20/K24 Valve Cover, D16A6 SOHC, EF CRX Extended Hood Prop
Old Mar 7, 2017 | 09:11 AM
ZCHondaCRX91's Avatar
Default FS: Powdercoated K20/K24 Valve Cover, D16A6 SOHC, EF CRX Extended Hood Prop
Prices are shipped to lower 48 US, if your shipping address is elsewhere please PM for quote. Most parts used for a very short time, but were cleaned to like new condition. Items located near Seattle, WA. Paypal payment only.
- K24A2 Valve Cover, Powdercoated Gloss Red with bare metal lettering. Doesn't include gaskets or seals, or any external parts. There is a small crack on the timing chain side in the middle, but it's very small and not seen from the outside. The finish is a high durability finish so it isn't perfectly smooth, but looks great compared to some of the low grade paint jobs commonly seen. $110 shipped.
-D15/D16 Non-vtec SOHC Valve Covers. One if powdercoated wrinkle red and the other is gloss yellow. The wrinkle red has some roughtness around the right-hand side grommet, it isn't really noticed until you feel it with your hand. Neither valve cover come with gaskets or seals, or any external parts. Either valve cover will fit: D15B1/2/6/7, D16A6, and SOHC Non-vtec ZC. $83 shipped for each.
-1988-1991 Civic/CRX extended hood prop. Basically it is the factory hoop prop extended using DOM steel tube and threaded at the ends. Then powdercoated wrinkle black. It is extended by 4 inches or so, which allow the hood to open near vertical for easy access. Requires no cutting and installs in a couple minutes. This is my last one. $38 shipped.
Old Mar 10, 2017 | 07:11 AM
Default Re: FS: Powdercoated K20/K24 Valve Cover, D16A6 SOHC, EF CRX Extended Hood Prop
Red A6 - SOLD
Old Mar 13, 2017 | 08:54 AM
ttt
JDM_SOHC
142
Jan 21, 2012 09:28 AM
lejeaune
Mar 28, 2008 10:54 AM
Rob.
Jun 25, 2007 12:46 AM
