Discussion: B16A2 Automatic Trans vs. Manual Trans Differences
hey guys , is there any significant differences between a b16a2 Auto Vs Manual?
any thing needed to be converted to get it to work with a manual transmission?
Thank You
Thank You
Camshafts are slightly different. The automatic camshafts are a lower profile IIRC. Bolting up a manual transmission will not be a problem. Make sure you change ECUs.
Ok if thats all thats not bad . plugs should be good to ? It should plug right up ? Im going to swap the auto b16 for the manual b16 i currently have in my 94 hatch so i can keep the civic on the road while i build the manual b16
vietherbs
Sep 9, 2007 08:38 PM
A2_8U
Jun 28, 2004 08:36 PM
