Adjusting clutch pressure soft vs hard
Old Mar 7, 2017 | 01:15 AM
xboxhaxorz's Avatar
Default Adjusting clutch pressure soft vs hard
Just bought a 97 vtec del sol and the clutch is super hard, requires strength to use it where as my 97 si is quite soft, owner said he thinks it had a clutch replacement
I have a muscle disorder so pressing the clutch fatigues me pretty quick and i wanted to change it, the owner said it could be done since its a hydraulic clutch but im not locating any information no how this can be done
Old Mar 7, 2017 | 04:28 AM
mk378's Avatar
Default Re: Adjusting clutch pressure soft vs hard
A racing clutch would have a stiffer main spring in the clutch cover. That means more force is needed to press the clutch pedal. You would need to remove the transmission and replace the clutch set with stock parts to change that.
Old Mar 7, 2017 | 06:47 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Check the clutch master cylinder, make sure it wasn't replaced with the Omni power unit. Those are known to be quite stiff.
Old Mar 7, 2017 | 06:58 AM
DumpdEJ6's Avatar
I like the tuna here
He could conceivably replace the clutch master cylinder with one with a smaller/longer piston and that would reduce the pedal effort, correct?
blacklabel14
Feb 3, 2011 12:32 PM
veilsides2000
Honda S2000
Jan 30, 2009 02:20 PM
tvman
Jul 16, 2005 11:30 AM
geminis2k
Nov 20, 2003 11:33 AM
