2000 Civic EX Overheating
Old Mar 5, 2017 | 07:35 PM
JFKHasNoBrain's Avatar
Default 2000 Civic EX Overheating
Ok so I have a 2000 Civic Ex that is overheating. I took it to a mechanic to see if they could just look at it. They checked for leaks, no leaks. They checked the fan, fan was fine. Radiator was brand new. They checked the coolant, said it was low and did a coolant flush. I took the car home and drove it around. It started slightly overheating while idling but cooled once I started driving again. Now I get about 20 minutes down the road and the check engine light flashes and the motor would seem to not want to go anywhere. I kept my foot on the gas and it would just go back to normal driving after a few moments. The engine light would stop flashing, everything would be normal until I had to come to a stop and pick back up again. So I went and had my spark plugs, wires, rotor, and distributor cap replaced. Car seemed to be running really well, nomore sputtering. Now before all the new plugs were put it, the guy doing it said he could feel the motor "thumping". I guess I should add we did a diagnostic scan and it came back with a cylinder 1 and 2 misfire, also (bank 1 sensor 2) circuit low input. Now with new plugs and wires I went home. Half way there my engine started to overheat. I got back and did a compression test on all 4 cylinders and got a reading of 160ish PSI. The second cylinder did not crank as high, it was in the 150 range, also was a dry test. Now after this I read online another way to test for a blown head is to leave the radiator cap on and start the car, if it shoots up like a geyser its a head problem. Anyways so it shot up, I put the cap back on and now decided to get others inputs. Is the radiator cap thing true? Anyone else have a problem like this?
Car Information-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
2000 Honda Civic EX 5 spd Manual
D16ya motor-rebuilt
Less then 50k miles
Old Mar 6, 2017 | 04:16 AM
Espincivic's Avatar
Default Re: 2000 Civic EX Overheating
easy not enough coolant or stuck thermostat
Old Mar 6, 2017 | 05:23 AM
mk378's Avatar
Yes if coolant shoots out of the radiator when you rev the engine cold with the cap off, the head gasket is blown. That is rather conclusive. On a good engine there is little or no action in the radiator until after the engine warms up.
Your repeated driving overheated isn't helping things.
Old Mar 6, 2017 | 08:17 AM
OK I didn't rev it with the cap off. I took the cap off, started the car, and coolant shut up. I am going to go out and try reving it with the cap off though. Also while the cap was off I didn't see any bubbles coming up from inside the radiator. I'm thinking now it could be a bad water pump? But if it was the water pump wouldn't it overheat all the time and not just in idle?
93CivicSiSOHC
Mar 10, 2016 07:45 AM
Jakester9500
Jan 30, 2015 01:57 PM
pmr100
Mar 5, 2014 07:37 PM
accord_2dr
14
Apr 15, 2013 09:08 PM
DWOL
Feb 9, 2009 07:32 PM
