2000 accord coolant leak-best approach to fix
Old Mar 4, 2017 | 07:41 PM
accord96lx's Avatar
Photogenic
Photoriffic
Shutterbug
Default 2000 accord coolant leak-best approach to fix
Starting steaming yesterday, coolant spraying under the hood.
This is most likely a simple cracked radiator but before I start dismantling it what would be the problem checklist you guys recommend?
And if it does turn out to be a radiator leak, I would think its best to replace it vs trying to fix. If so which brand of radiator from what seller would you think to buy from?
Heres a pic
Old Mar 5, 2017 | 12:32 AM
holmesnmanny's Avatar
Default Re: 2000 accord coolant leak-best approach to fix
2000 HONDA ACCORD 2.3L L4 Radiator | RockAuto
Denso is OEM
Old Mar 5, 2017 | 05:56 AM
accord96lx's Avatar
Photogenic
Photoriffic
Shutterbug
Thanks! Are there any other things that would be failing and cause this kind of leak? Before I just replaced it I was wondering if there were other things to check.
I didnt see any leaks coming from hoses or connections from a glance.
Old Mar 5, 2017 | 07:07 AM
that_boy_sammy's Avatar
Buy one from AutoZone or oreillys.
Old Mar 5, 2017 | 09:37 AM
Northernlightz's Avatar
Removing an old hose and reinstalling it afterwards can lead to a nasty surprise down the road. It is best to replace old hoses, even if they appear to be in good condition.
Old Mar 10, 2017 | 04:34 PM
accord96lx's Avatar
Photogenic
Photoriffic
Shutterbug
I replaced the upper and lower radiator hoses, radiator (denso) and the thermostat and seal.
What I'm seeing now is that the radiator fan is not turning on when Im driving around...unless the AC is on then both fans run.
I assume the temp sending unit is bad on the thermostat housing? Or could there be another issue?
vtec2017
Mar 18, 2017 04:24 PM
Ren3gade10
Aug 13, 2015 05:15 AM
trent52hgc
Feb 19, 2015 07:35 PM
jap305
Nov 21, 2011 09:52 AM
94acurals
Dec 5, 2001 05:32 AM
