Will my springs settle?
Old Nov 9, 2002 | 04:03 PM
b16EF's Avatar
Default Will my springs settle?
I just got done putting my stock springs and struts back into my 96 EX coupeafter having skunk2 coiloers in the car for two years, all went well till I finished the job and stood back and looked at the car. The thing looks like i just installed a lift kit into the car, it looks ridiculus. Is this normal, will it eventually settle down? I know the car shouldnt sit this high. Thanks
[Modified by b16EF, 8:04 PM 11/9/2002]
Old Nov 9, 2002 | 04:04 PM
Kamin's Avatar
Default Re: Will my springs settle? (b16EF)
yes
they will go back to stock heigth.
Old Nov 9, 2002 | 04:09 PM
Jin Yamato's Avatar
Default Re: Will my springs settle? (KAMiN)
OT: Kamin sweet sound setup on the sleeper
Old Nov 9, 2002 | 04:17 PM
Kamin's Avatar
Default Re: Will my springs settle? (jin_)
hehe thanks
Old Nov 9, 2002 | 04:32 PM
Amuse9's Avatar
Did you compress your stock springs first? cause you need to compress the spring if u r going to raise your car, (i might bee wrong)
Old Nov 10, 2002 | 06:54 AM
b16EF's Avatar
Default Re: Will my springs settle? (CivicSedan)
I had to compress them to put them back on the struts. But that is the only compressing of the springs that iI did.
Old Nov 10, 2002 | 08:13 AM
Briman2021's Avatar
They will settle back down, this happens every time i jack up my car even, they will be around .5" above where they finally settle to, but this is on a 97 ex coupe, not a 96, so there might be some difference in the springs, so i dont know how much yours will settle. Should be pretty close tho.
[Modified by Briman2021, 9:14 AM 11/10/2002]
Old Nov 10, 2002 | 08:21 AM
MrJasey's Avatar
Default Re: Will my springs settle? (Briman2021)
if u reinstalled everything correctly, they SHOULD settle to normal hieght
jeddyminit
Oct 18, 2011 05:41 PM
admess188
Nov 25, 2008 01:22 PM
5800vtec
Apr 14, 2008 11:13 PM
GreddyTegra
Jun 27, 2006 08:16 AM
bo0sted
May 28, 2004 01:45 PM
