Honda CR-V & Element 2WD & 4WD Element & CR-V
HONDA CRV 2001 OVERHEATING OIL LEAKAGE
Old Mar 2, 2017 | 10:33 AM
Chawki Malek's Avatar
Default HONDA CRV 2001 OVERHEATING OIL LEAKAGE
My car was overheating and did not work easily in the morning I took it to the repairman to fix it .
one week later I got my car working apparently but still hard to work in the morning . here at that time the degree was -4 celsius (Ankara).
one week later the same overheating problem emerged .
I found out that the radiator was leaking and there is leakage of coolant down the hoses so i changed all hoses and radiator also I found out that the coolant temp sensor was out of fucntion so ı changed it .
now i found that the oil is leaking and it is oily under the engine block .
my question ........most of the time where should I look when there is oil leaking ?
what can be causing the hard start i the morning?
Jon Petersen
Jul 22, 2018 12:04 PM
aristo808
Jan 31, 2012 05:31 AM
pjg
Mar 8, 2010 03:50 PM
y2kferari
May 3, 2009 11:05 PM
profesional-hobo
Apr 17, 2009 07:28 AM
