very URGENT help!!
Old Nov 9, 2002 | 03:24 PM
Import RP's Avatar
Default very URGENT help!!
I am in the process of changing my clutch. We have the tranny out and the flywheel off. I noticed that the crank seal behind the flywheel appears to be leaking a little bit. I have a seal in my hand right now, but I'm not sure how to change it. Does it just pop in and out or what? I really wanna change it since we are in there, but I dont want to mess up and have to take the whole thing apart again. PLEASE TELL ME HOW TO CHANGE THE SEAL!!! Thanks!!!
Old Nov 9, 2002 | 03:28 PM
ImportReview
Guest
Posts: n/a
Default Re: very URGENT help!! (Pyrochaos38)
Its easy. Thats the rear main seal.
Take out all the 10 MM bolts, pry it off with screwdriver...then
You will have to pound it out with a rubber mallet or something like that, its a pressure fit.
Then put it back in, and tap it in with mallet.
Then put honda bond around edges of metal that the bolts go into, so it does not leak from the bolt area part, and put it back on.
Good luck, i hope I helped.
At first, its hard to see it pops out, its a really tight pressure fit.
Jeff
Old Nov 12, 2002 | 08:19 PM
Import RP's Avatar
Default Re: very URGENT help!! (ImportReview)
Hey, thanks a lot for the response! I think I got it in right. Its been 3 days now, and no leaks
toooslow
Aug 21, 2003 05:43 AM
ludesleep
Apr 1, 2003 02:35 PM
Import RP
Nov 9, 2002 03:49 PM
navin
Apr 4, 2002 06:46 PM
