Suspension & Brakes Theory, alignment, spring rates....
949 6UL Wheels not clearing brakes near hub...?
Old Feb 28, 2017 | 05:35 PM
2x0's Avatar
2x0
10 Year Member
Default 949 6UL Wheels not clearing brakes near hub...?
So as I have been inspecting this CRX further that I recently bought, I noticed there is NO clearance between the front caliper and inside of the wheel spokes near the hub.
These are 949 6UL in I believe 15x8 +36 size. PO told me they are 15x9, but not sure I believe it. I need to pull them off and see what damage is done to the wheel.
They are so close, only the driver side appears to have scraped the finish off the caliper.
This is also supposedly a big brake kit, idk where he got it from. Anyone else seen issues with these wheels and brake clearance?
Does this seem safe to drive?
Old Feb 28, 2017 | 07:15 PM
redlinetuning's Avatar
Default Re: 949 6UL Wheels not clearing brakes near hub...?
so take it off and inspect it.. stop speculating on the internet.
Old Feb 28, 2017 | 07:35 PM
2x0's Avatar
2x0
10 Year Member
Okay thanks...
Yep, inside of wheel is scraped from it.
Anyone else had a similar experience with these wheels?
Old Mar 2, 2017 | 01:51 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
If the wheel is contacting the brakes...is it safe to drive?
Probably not.
No.
You should check out the wheel size/offset. Then figure out what brakes they are.
Then figure out what brakes fit.
You're going to have to do most of that anyway. How would you buy pads or calipers or rotors in the future?
Have you contacted the PO?
Old Mar 2, 2017 | 02:09 PM
KoRn_vIRuZ's Avatar
I had the same problem on a Fit. The small 240 mm brake caliper sits really close to the hub and would rub the wheel (it was an OEM 14" wheel from a Civic). I used a small spacer to fix it and suggest you do the same.
Old Mar 2, 2017 | 03:10 PM
2x0's Avatar
2x0
10 Year Member
Looks like brake pads may have just been replaced, they are very thick and may have caused momentary contact. It does not obstruct the wheel from spinning freely while off the ground.
Getting some 3mm spacers, even though my tires are already wider than the fenders... but I'll have no choice until I get new wheels or brakes.
Old Mar 2, 2017 | 03:51 PM
KoRn_vIRuZ's Avatar
Larger diameter brakes will also fix the issue.
Old Mar 2, 2017 | 04:20 PM
2x0's Avatar
2x0
10 Year Member
Great point!
But, I will try to refrain from making any major mods yet... need to get the car roadworthy first. But I didn't even think that of the fact that larger diameter would push the caliper away from the hub and increase clearance.
Thanks for the suggestion!
civic-one
Sep 14, 2013 06:04 AM
lxstuart
Suspension & Brakes
Oct 17, 2009 09:46 PM
red civic standard
Jun 6, 2006 07:20 AM
tytyguy
May 3, 2006 04:35 PM
Si_Racer13
20
Feb 9, 2005 03:04 PM
