omni front lower control arm replacment bushings
Old Feb 27, 2017 | 08:00 PM
beefystud's Avatar
Default omni front lower control arm replacment bushings
will after market bushings from prothane or energy fit into these control arms ?
Omni Front Lower Control Arm Honda Civic (1992-1995) EGFLCA
Old Feb 27, 2017 | 09:49 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: omni front lower control arm replacment bushings
You will most likely have to contact the manufacturer or the distributor to find out the bushing sizes.
Old Feb 27, 2017 | 11:28 PM
beefystud's Avatar
first hand experience is king, so many variables when it comes to "sizes" the dimensions of the bushings can very so much.
Old Mar 1, 2017 | 02:02 AM
beefystud's Avatar
also omni has not produced these control arms in over a decade , there all left over stock , no one wants them cause the bushings are ****....
Old Mar 1, 2017 | 06:05 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I guess the other option since no one seems to have insight is to push the bushings out and measure. Then contact ES and see if they can match up the dimensions.
Old Mar 1, 2017 | 07:39 AM
joey1320's Avatar
Ahhh $400 for non-adjustable, inferior quality metals and **** bushings... Why, why, why?
Keep your OEM ones, get them powder coated to make them look pretty and order either OEM or a good reputable replacement set of bushings.
Old Mar 1, 2017 | 07:44 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
You'd swear this **** is hard.
Adjustable front lower control arms? lolwat?
Also, they're made from T6-2014 aluminum, which is way stronger than even 7075, so you clearly have no idea what you're talking about.
I'll give you the bushings aren't great. Poly sucks honestly.
Old Mar 1, 2017 | 07:59 AM
joey1320's Avatar
I've seen aftermarket front control arms where an extra hole (or two) for the sway bar link is added to change the torsion rate. Sorry if I didn't specify.
Yes, adjustable sway bar links and or a different sway bar would do the same, but I've seen them. So this is rather a good looking shiny piece that doesn't do much difference unless 8lbs of weight loss, as stated by OMNI, is that important. On a daily driver, nobody will tell the difference imo.
It doesn't say so in that link. Not saying they are not but the specs, or lack thereof, made me think of low quality materials. I wouldn't care to look in OMNI's own site.
I'll stick with my stock/Sankei(555) lca's and OEM/Hardrace bushings.
Again, $400 for no gains other than looks(weight loss) is rather steep imo.
Old Mar 1, 2017 | 03:13 PM
BryanM.'s Avatar
Resident Gearhead
To each his own but maaaan those are expensive. The stock iron LCAs are great IMO
axis11
Suspension & Brakes
Mar 9, 2012 09:21 AM
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
kornerk12
Aug 3, 2008 09:10 AM
SoulSurfer
Dec 10, 2002 10:45 AM
