92-95- trans in 99-00 Conversion mount needed?
What mounts needed for a 92-95 trans into a 99-00 Is the expensive custom mount needed??? Which exact mounts do i need? so many conflicting opinions and most are putting a 96-00 trans into a 96-00 car etc; how about a 92-95 manual trans into a 99-00 car? which trans mounts do i need?
IS the custom mount needed for the BODY part of a 92-95 car? or is it in the trans case? im putting a 93 manual trans into a auto 99 car- what mounts are needed.
The case is the same from 92-00.
Therefore you just need to follow the auto to manual swap guide in the FAQ on the top of this 92-00 tech forum.
https://honda-tech.com/forums/honda-...4pics-1337459/
Looks like you just need the bracket from a manual 96-00 chassis.
The chassis itself is what is important when it comes to parts you need for your conversion.
The transmission doesn't matter as long as it's a Hydraulic D series.
Yep, you'll need the upper transmission mount and bracket from a '96 - '00 5 speed Civic (unless it's an HX coupe, in that case you will need a custom mount)
Hey, today i pulled all the rest of what i needed off a 93 civic but i noticed the mounts have HUGE brackets (on the back of the trans is a huge bracket) and the chassis is different (on the top mount that holds the trans) than my 99 car- so my 93 manual trans still bolts up to my 99 car- Its JUST that i need MANUAL 96-00 mounts correct?
RACEPAK
Nov 30, 2006 04:59 PM
Surewin
Nov 29, 2005 10:26 PM
