CRX is Not holding Charge
Old Feb 26, 2017 | 05:29 PM
CRXSTRUGGLE's Avatar
Default CRX is Not holding Charge
CRX is not holding battery charge,
AAA tested said the Alt tested at 9.5
the car ran for a little bit but then would stall and not start,,, can a car run on a dead battery if you pop the clutch ,? do I need a new Alternator? can you help me out ?
Thank you
Old Feb 26, 2017 | 07:19 PM
God Is Bed's Avatar
Default Re: CRX is Not holding Charge
You probably need a new alternator. Swing by a Batteries Plus or Autozone and have them test the alternator. You can run a car on a dead battery, but your alternator has to be good. At 9.5 volts, you most likely need a new battery unless yours is less than a year old. Then it might come back.
Old Mar 27, 2017 | 07:53 PM
Old Mar 27, 2017 | 08:00 PM
they could not test at Autozone b/c they did not have the wires,,, so I bought a new alt
and charged the battery, started right up! Drove for a hour no Problem ,,,
any ideas where I can sell my Honda ?
CRX Si unmolested 1.6
most all parts are Lifetime warranty from Autozone and Passes Smog and Registered.
Any help
Old Mar 28, 2017 | 07:24 PM
Tyson's Avatar
I don't get it. You you want to sell your car because you can't replace the alternator?
Old Mar 29, 2017 | 07:43 AM
tommycrx's Avatar
It's a struggle, obviously.
Old Mar 29, 2017 | 08:22 AM
HaHaHa No, the car is fixed now it was the Alt
now I want to sell her,
Sure is 100
Old Mar 29, 2017 | 11:26 AM
4drEF's Avatar
Keyboard Humorist
I'll give you tree fiddy, but you have to deliver and smog it.
Craigslist.
KYDelSol
Aug 19, 2012 08:30 AM
robble36
Oct 18, 2007 05:19 AM
Freezen
Aug 6, 2007 01:12 PM
Byaaah!
Jan 30, 2007 12:06 AM
Cryptopsy
Aug 13, 2005 04:04 PM
