93 Civic VX no start have fuel
93 Civic VX D15Z1 no start have fuel
so plugs get wet after enough cranking but no spark. new distributor.
took cap and rotor and plastic cover off.
positive screw is hot when key is on and isnt when cranking
any help would be nice
Pull the brake handle up, does the brake light come on when you turn the key on, and stay on while cranking-- it should. If it does not, the ignition switch is likely the problem.
How big are the sparks you can get from the coil? They should be blue and able to jump more than 1/2 inch to a grounded test wire. If you only have little yellow sparks the coil is bad.
The coil is prone to blow from firing into an open circuit. Always hold a grounded test wire near the coil output when cranking to test for spark.
No spark but tested the yellow with green stripe wire and it's not flashing like it is supposed to.
Also as far as parking brake light it stays lit when cranking.
spoonhbk11
11
Jun 9, 2019 07:03 PM
the soL that could
15
Aug 27, 2011 06:44 PM
