B18C1 Swap B series civic EK swap/parts for sale
All prices OBO
Paypal included
Take everything for $2,000obo
The only trade I will accept is a motorcycle, looking for something 250-650cc, ninja, honda, sportbike, dualsport, etc.
Located in Modesto, CA.
OBD2A EX harness converted for USDM B18C1 - SOLD
Innovative Billet Mounts - $180 shipped
EK B/D Series IIRC.
3 bolt driver post mount.
Includes Si rear bracket, Driver side bracket, Passenger side bracket.
Passenger mount has a tear
Driver is good to go
Rear is chowdered (see pics)
Shift linkage $40+shipping (I'll get you a quote, idk how much it would cost)
Del Sol B16 transmission+Quaife helical LSD - SOLD
Gear set is in great condition
Case passenger side lower torque? mount is fuxored and not useable. Needs new studs most likely for the top mount. I can sell the gear set+LSD minus the case as well, toss me an offer.
Flywheel cover $20 shipped
USDM B18C1 Long Block $800 I suspect the head gasket needs to be replaced. VIN attached to the block.
Shipping needs to be calculated for this. I can palletize it and ship it that way through my work, Idk how much it will cost.
It's semi taken apart but I have the parts/bolts bagged and labeled.
Or...
Head with VTEC solenoid, cams, valvetrain, IM, Distributor etc - $400+shipping
(I'm willing to sell the Intake Manifold, Distributor separate, or sell the head without for a lower price. Valvetrain/cams/gears stay with the head)
Block with oil pump, pan, complete rotating assembly, new t belt, new water pump, t belt covers etc - $400+shipping
I have a bunch of misc seals/gaskets/parts for the head and block that will go with it. Literally $400 worth of OEM parts.
Starter - $60 shipped
Alternator - $40 shipped
It's covered in oil, I am not going to clean it.
Axles $20+shipping. They're basically good for cores
Intermediate Shaft $40+shipping
Alternator Bracket $30 shipped
GSR OEM header $30 (has a dent on the bottom)
OBD2 P72-A04 ecu $60 shipped
VTEC solenoid cover $20 shipped
ACT flywheel/PP/Clutch kit. $120 shipped
Lightweight flywheel (8.9lbs?)
clutch was soaked in oil (rear main seal was shot on the block)
PP and flywheel would be good to go with a cleaning and resurfacing.
Exedy OEM replacement clutch kit $120 shipped
Take all the clutch stuff for $200 shipped
OE Radiator $40 shipped
Overflow tank $15 shipped
Aftermarket 99-00 front bumper $20 picked up.
Rep 96-98 CTR grille $20 shipped
yellow fog lights $20 shipped
OEM GS-R Spark plug wires, new in package - $50 shipped
OEM GS-R Timing Belt, new in package - $50 shipped
OEM vtec water pump, new in package - $80 shipped
OEM Distributor Coil. new in package, but opened. - $60 shipped
I'm still in the process of taking pictures of parts but will get them up ASAP, as well as digging out whatever else I have for sale.
Paypal included
EK B/D Series IIRC.
Or...
Transmission sold, wire harness sold, will update in a bit.
2Live EM1, which bike? The whitewall tire one? $60
Why's the audience a bunch of hoes?
@sik, I am not 100% sure if it's an SI or GSR shift linkage. The swap was in another civic, I know that much.
