B18 swap
Old Nov 9, 2002 | 02:46 PM
slow hatch's Avatar
Default B18 swap
Does anyone have a list of stuff i need to have to put a B18a1 into my civic hatchback. I have a 90' integra for parts to use.
If anyone does it would help alot. Thanks.
Old Nov 9, 2002 | 04:28 PM
Aphrodavid's Avatar
Default Re: B18 swap (88' Honda Hatch)
depends on what trim model you have. if you have an SI, no changes to the suspension are nessesary. if you have a DX, then you will have to switch to SI or 2nsd gen teg hubs. other than that, youll need.
b18a motor
b series tranny
non-obd LS ecu
custom shift linkage
90-93 teg axles
if you have DPFI, then you will have to convert to MPFI as well. after that, the LS ecu will plug right into the stock harness. since theres no vtec, you wont have any other wiring to do either.
Old Nov 9, 2002 | 04:36 PM
Rob!'s Avatar
Default Re: B18 swap (Braveheezy)
http://www.hasport.com tells you everything you need.
ximportman
Jan 24, 2009 09:39 PM
.Noah Fecks
Aug 23, 2003 12:54 AM
MisterHYBRID
Jan 24, 2003 07:03 PM
slow hatch
Nov 13, 2002 06:58 PM
Blaze45
Sep 22, 2002 08:08 AM
