91 Civic OBD1 Swap - Fuel Pump Relay no signal
Old Feb 23, 2017 | 07:57 AM
MervTeck's Avatar
Default 91 Civic OBD1 Swap - Fuel Pump Relay no signal
So i have a 91 Civic Sedan with the B20b swapped in, untill 2 days ago she ran fine on an OBD0 MPFI swap i had done a year ago.
Got the parts for OBD1 swap, (adapter harness for dizzy and ECU, 4 wire o2 sensor, running a chipped P06 ECU, OBD1 Dizzy)
I installed all the parts and went to start the car up and got crank but no fire.
Tested for spark and got great spark.
Tested for fuel, no fuel. Checked the fuel pump relay. only was getting a light singular click with no fuel pump turning on
with relay installed i jumped pin 8 to make sure i still had a fuel pump, even replaced the relay for ***** and giggles same result
and yes the groud on the thermostat housing is attached =p
Any help will do guys! i appreciate it!
Old Feb 23, 2017 | 03:57 PM
MervTeck's Avatar
Default Re: 91 Civic OBD1 Swap - Fuel Pump Relay no signal
ran a test on relay and relay harness according to this post https://honda-tech.com/forums/honda-...-pics-2535047/ and
tested the continuity of the zif socket to its respective chips according to this Troubleshooting a Honda P28 Chip Installation ? Technical Domain
also soldered and installed jumper pins to the J1 for easy removal. tried turning on without jumper but still not fuel pump.
Ideas please!
stickman78114
Feb 22, 2010 02:14 PM
SrT4u2nV
Dec 7, 2006 06:10 PM
MarkAngelo
May 18, 2004 03:51 PM
civicrtype
Feb 26, 2003 04:22 PM
