o just get a new cheap headers (yeah I know but wait)
for no reason I just bought it.
description more HP, shiny and more shiny
installed fit good but guess what exhaust leak between the dowpipe and catalytic won't fit properly yes came with the donut gasket, and rattle very annoying every red light, no brakets like my oem. Any way before I throw this away, any solution for this.
if not I wonder what kind of donut gasket I need for my OEM header part number? Hope you guys can help. I Learn the lesson don't buy cheap stuff hahah well sometimes.
tomcat39 yeah i will try using clamps before tight the nuts i just use the hardware came with the header bolts nuts gasket etc ....... yeah its a cheap header like $45 free shipping super cheap””” thanks civic402lx i found the part
Honda Part No.: 18229-S01-X11
Gasket, Flexible EX. (51mm Id.- 64mm Od.)
i try to keep the aftermarket header if doesn’t work well i put the stock one back i will keep you guys update
Did you have any difficulty installing those headers? I just purchased a full exhaust kit so i suppose the alignment issue you're facing isn't something ill be dealing with seeing how the CAT will be in the trash can when i am finished.
not at all just that annoying gap between the cat and the down pipe.... yeah well I got the axel back I think I make a mistake well be more easy and CHEAP bought the whole kit but o well. Keep post I want to see how it's sound
Because you cinched down the springs for the flex gasket you have bent the flange.
It's no longer flat and level and makes contact to the other flange.
That is going to cause you problems even though you fixed the springs by using the proper bolts.
that at one was for the axle back muffler was really bad leak.
I will try one of this days fix the cat downpipe later with the same donut gasket but this time I will use some clamps. Will see if not I'm about to take to the shop and welded or put the oem header back any suggestions?
