Suspension & Brakes Theory, alignment, spring rates....
Need advice!
Old Feb 21, 2017 | 09:02 PM
ej8stock's Avatar
Default Need advice!
I have a 99 civic that I purchased with Megan Racing EZ street coilovers on and I want to change the springs. Not sure what to go with and whether they would fit on the Megan coilovers. I daily drive the car but also like aggressive driving on weekends. I do not have the budget for new coilovers but I am willing to spend up to 300$ on quality springs. Any help is appreciated.
Old Feb 22, 2017 | 04:45 PM
cisco_kid's Avatar
Default Re: Need advice!
well anything is better than Megan Racing..lol
I'm not sure if you can just buy springs to put on coilobers but..
With 300 as budget I'm sure you can find Springs from TEIN, Eibach and H&R that will be within your price and definitely a big improvement over Megan Racings.
Don't go too low if you're going to use stock shocks thoug​​​​​​h..
Old Feb 22, 2017 | 05:27 PM
jdmpowered's Avatar
i had at one point put on a couple hundred dollar set of one piece eibachs w/ inch or 2 of drop and was very happy
If you are on the fence about it just wait till you have the cash else you are just going to be buying something you really didn't want and then turn around later and spend more later to get what you think you want. so you're actually spending more in the end to get what you wanted.
agree w/ cisco.... if you don't know when to go and when to slow you break more stuff.....unless you're into dragging the ground everywhere you go some people like that kind of thing...lol
Old Feb 22, 2017 | 08:47 PM
ej8stock's Avatar
Should I get some OEM shocks then to accept the springs? I'm trying to raise the car right now but I don't have anywhere to go in maxed out and I'm so low.
Old Feb 22, 2017 | 08:49 PM
ej8stock's Avatar
so you mean wait until i have the money to buy a new set of coilovers? Don't like being this low it bothers me but I bought the car this way. I really just want to put spring on these Megan adjustable coilovers and call it a day.
Old Feb 22, 2017 | 08:50 PM
ej8stock's Avatar
By the way Thankyou everyone so far for the advice! Much appreciated
Old Feb 23, 2017 | 08:14 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Your height adjustment is maxed out?
Can you add more preload to the spring to raise the car? It will likely ride better because you're giving the shock more room to work.
That solution is free.
Then just save the extra $500-600 you need in order to purchase a decent set of coilovers.
If you want springs....springs are available from Eibach or Ground Control. Or Swift. Or hyperco. Or H&R. 100X other spring suppliers. Or Summit if you want them cheap.
You just need *flat bottom* springs with the same diameter as your originals. You do NOT want lowering springs that are application specific. But...what do you plan on doing? Just buying extremely stiff springs so the car sits higher? Will the dampers be able to handle that?
It may help to take photos if your coilovers, your current ride height, and how you are attempting to adjust them.
Old Feb 23, 2017 | 08:48 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
This is another one of those threads where we need to back up and find out what the intended goal of the OP is. Buying springs for Megan Racing coilovers should have been the first flag.
OP - check to see if the coilovers are stuffed down into the shock mount, it's a common trick people use to go lower then coilovers would normally allow them. Also, make sure you're adjusting the coilovers by the bottom perch, not by the perches the springs rest on. Can you take a pic of your tire gap, and then one of the suspension setup?
Old Feb 23, 2017 | 10:13 AM
Bitch Puddin''s Avatar
save some money and do it right OP. A legit coilover system w/ adjustable dampening shocks.
I got and APEXi system, don't remember what kind but I don't have any complaints.
Old Feb 23, 2017 | 02:59 PM
B serious's Avatar
....but....
Apex'i EXV is the same as Megan Racing.
Old Feb 23, 2017 | 03:02 PM
B serious's Avatar
Sir! I will have you know....
Old Feb 23, 2017 | 05:07 PM
....but....
I dont have the EXV model.
Old Feb 23, 2017 | 06:50 PM
jdmpowered's Avatar
sorry too late when i read and posted...agree w/ b serious if they are fully adjustable turn those things up an inch or so and see how it is. You would think that you could swap the springs out w/ no issue; maybe maybe not. if it was mine id call megan racing and double check before you blow the suspension apart drop cash on new springs only to fine out it won't work.
is there adj ball joints or anything on it? if you start screwing w/ the ride height and get it where you like it probably not a bad idea to get an alignment check
Old Feb 23, 2017 | 07:17 PM
ej8stock's Avatar
Haven't been able to raise the car anymore. I've seen several videos how to adjust them but my springs are way too short. i will get pictures. thankyou
Old Feb 23, 2017 | 07:19 PM
ej8stock's Avatar
i didn't buy them. i don't have money right now for new ones. kinda want to improve this. I'm also working on something else at the moment and thats where all my cash is going right now. not sure about the coilers being stuffed down. i will get pictures. thank you !
Old Feb 23, 2017 | 07:20 PM
ej8stock's Avatar
Old Feb 23, 2017 | 07:22 PM
ej8stock's Avatar
could do this but its gonna take a while. I'm building a b20 right now. these are just too low, don't ride all that bad. thank you!
Old Feb 23, 2017 | 07:24 PM
ej8stock's Avatar
alignments are not an issue, i know a guy. i will get some pictures. they're maxed out; the springs are too short. not trying to blow the suspension. how would i avoid this if i did go with springs? thank you!
Old Feb 23, 2017 | 07:32 PM
ej8stock's Avatar
not the best but its what i have for right now(screen shot from a video). will get more pictures tomorrow after class. thank you everyone for the replies; all help and advice is appreciated.
Old Feb 24, 2017 | 07:37 AM
do you still have your stock shocks? maybe pairing them up with some used H&R or Eibach springs would be a good bet.
Old Feb 24, 2017 | 08:51 AM
ej8stock's Avatar
never had em. Probably could buy some but at that point I might aswell just take that $$ and put it into coilovers
Old Feb 27, 2017 | 05:45 AM
yep.
Old Feb 27, 2017 | 02:51 PM
ej8stock's Avatar
yep.
I have more pictures. I will be uploading them to my computer right now and posting them here.
Old Feb 27, 2017 | 03:38 PM
2LEM1's Avatar
I like to party
Community Builder
The suspense is killing me.
Old Feb 28, 2017 | 06:52 PM
2LEM1's Avatar
I like to party
Community Builder
