screw driver got stuck while timing.
Old Feb 21, 2017 | 06:11 PM
ordale's Avatar
Default screw driver got stuck while timing.
While I was finding top dead center, I noticed my screw driver wasn't rising out of the number one cylinder. I wiggled it a bit and started to turn my crank bolt again. Well as it was rising felt unwarranted restriction while rotating the crank. I found out it was my screw driver getting stuck and not raising all the way.
Has this ever happened to anyone before? I wasn't using a lot of force but is there something I could have screwed up while doing that? It came out without a fight after I back tracked the crank. I was like crap now what!!
Old Feb 21, 2017 | 09:05 PM
holmesnmanny's Avatar
Default Re: screw driver got stuck while timing.
You better compression test it. I really hope you didn't score the cylinder.
Old Feb 22, 2017 | 11:45 AM
ordale's Avatar
Dang that sucks. I hope not. I mean I wasn't putting a lot of pressure on it because t I guess after I put all my timing stuff together I'll do a compression test. I'm hoping it was just putting pressure at top of piston and spark plug hole. Thankyou for your input.
Old Feb 24, 2017 | 11:07 PM
smithers646's Avatar
next time use something plastic. I cut a leg off of an old plant hanger. Works like a champ. I even Sharpied the line for TDC at top of spark plug tube. Very handy for valve adjustments too.
drewsblackmax
Dec 19, 2010 10:49 AM
efjones9
10
Aug 5, 2010 03:31 PM
dateg91
Feb 4, 2007 10:55 AM
trecool44
Feb 12, 2006 06:08 PM
gerhard
Mar 8, 2005 02:46 AM
