GSR won't go past 7200rpm
Old Feb 19, 2017 | 11:13 AM
civic402lx's Avatar
Default GSR won't go past 7200rpm
I have a 96 gsr swapped eg sedan. Running on obd1 p72 ecu.. So the ecu is correct. In the pass, I remember I can rev up to 8000rpm. But lately for some weird reason it cut off at 7200rpm. No CEL, I jumped the 2 prong blue service connector. The cel stays solid the entire time. The only thing that blinks is the SRS light. It blinks continuously until u remove the key.
No air leak, no jumpy idle. Cap and rotor look perfect, oil is fresh and up to level. VTEC kicks in at 4k.
Mods:
Skunk2 IM
Ported stock tb
Generic header 2.5in collector
Magnaflow 2.5in cat converter
2.5in ss exhaust pipe fitted with Vibrant Ultra quiet Resonator and Apexi WS2 2.5in universal muffler.
Stock intake. New filter..
Timing dead on. Car drive and idle normal 850+/-rpm.
I also have a JDM obd1 p72 ecu to tried and same result. Cut off at 7200rpm, hit rev limiter..
Can't figure out what's going on. Since there is no CEL, I have nothing to go by.
Fuel filter is 2 yes old, car driven less then 7000 miles in 2 yrs. Fuel pump is gsr OEM, not civic. Pressure is in line with FSM spec. Already tested pressure.
I don't have an external tach to try but even if the civic tach is off, it shouldn't be off 800rpms.
Any suggestion?
JDM ecu part number is: 37820-p72-003
Usdm ecu part number is: 37820-p72-a01
Old Feb 22, 2017 | 10:58 AM
00blkSi's Avatar
Default Re: GSR won't go past 7200rpm
How's the compression?
Old Mar 11, 2017 | 09:37 PM
trm4life's Avatar
I believe, on my 92 gs, stock limit is 7200. You'd need to tune the ecu, or get a chipped ecu so u can tune it. ...
Old Mar 12, 2017 | 07:15 AM
Ryanthegreat1's Avatar
I thought fuel cut on a US p72 was 8200?
Your tach is probably off especially if it is cold.
EricEJ8
Feb 18, 2019 08:55 AM
civic402lx
10
Aug 30, 2018 09:46 AM
nuber1zero
May 15, 2014 04:23 PM
NVMYDC
Dec 29, 2010 10:52 PM
ludegetsmwet
Dec 2, 2004 01:32 PM
