Fuse 15 blows
Old Feb 18, 2017 | 10:16 AM
JimBobBob's Avatar
Icon5 Fuse 15 blows
I have a Canadian built 1996 Civic LX, with D16Y7 engine. I recently took a trip and on way back I got a CEL with codes P0135, P0141 and P0501. I also had pulsing headlight and dash lights. I wrongly assumed alternator was bad so changed that. I read one of the forums here and was pointed to fuse F15 being blown. I replaced F15 (which was blown) and everything seemed normal for about 5 min. F15 was blown again. I check under dash, no issues found. I disconnected big connector under hood as well as alternator small connector, both O2 sensors and VSS connector. Short seems to be on engine side of wiring harness, (black/yellow wire). I wonder if anything else is connected to circuit or do i just have a short in cable some where?
Old Feb 18, 2017 | 09:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Fuse 15 blows
Please see the attached TSB regarding Fuse 15 blowing and the engine wire harness:
TSB-x99-029e.pdf
Old Mar 18, 2022 | 12:57 PM
dalegtr's Avatar
Thanks for posting the pdf TomCat. Been battling with this issue for over a week. The diagram in the TSB is valuable.
RedneckRicer
20
Apr 9, 2014 08:19 PM
CrxGrin
Dec 17, 2012 07:06 PM
mtownsi
Sep 23, 2012 03:48 PM
Luiz_aka29
12
Aug 15, 2009 08:56 PM
Stock@$$GSR
Apr 5, 2007 05:23 PM
