Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 civic GX (CNG) crank no start after changing oil
Old Feb 17, 2017 | 11:02 PM
Jason Minahan's Avatar
Icon4 2003 civic GX (CNG) crank no start after changing oil
Howdy:
I was being a good Honda dad and changed the oil on my Civic GX and now it won't start.
It sounds weird when cranking, just. not quite right.
I have spark. (put a drill bit in the end of a boot and cranked)
After intermittently cranking for a bit, i still do not smell fuel out the exhaust.
I was ham-fisting around under the intake to get to the oil filter and may have bumped something?
I checked the fuses under the hood and under the dash that seeeeem like they would be related (nothing smoked).
I've got a code scanner:
No trouble codes thrown.
The following sensors seem good - they change readings when unplugged (while watching scanner)
IAT seems good
coolant seems good
map seems good
throttle position seems good.
When cranking, the ignition advance will go to 5deg
The following are maybe clues?
O2 sensors do not change readings when cranking (1.275V)
Unplugging the thing on the end of the fuel rail doesn't seem to cause anything to change. Including fuel pressure. Not sure if this is fuel pressure or something else (looks like fuel pressure sensor) the leads to this thing are getting 5v.
I can't get my ham fists to unplug the two things down by the passenger side, high pressure regulator?
vacuum line to ... demand fuel regulator? looks ok.
Some other details:
~213k miles.
I haven't changed the CNG fuel filters in forever, probably 50k. (totally forgot about 'em until researching problems)
Seeems like my fuel mileage has been crappier than when i bought it 80k miles ago, but otherwise, running ok.
I swear it started for a second after I changed the oil then chugged for a sec, then died.
Full tank of fuel. Filled up at a usually busy station in san jose. (not pge)
help!
Old Feb 18, 2017 | 05:11 AM
prodjay10's Avatar
Default Re: 2003 civic GX (CNG) crank no start after changing oil
Does the immobilizer light turn off after you turn the key or does it stay flashing?
Old Feb 19, 2017 | 11:17 PM
bbarbulo's Avatar
what rpm does it show on scan tool while cranking
Crowinghen
17
May 24, 2013 06:44 AM
aalb1
Sep 4, 2008 07:11 PM
crx18c1
11
Jun 18, 2007 06:42 PM
EKris
Mar 4, 2007 08:37 AM
Lsos
Feb 17, 2005 10:12 AM
