Car cranks turns over but wont start
Old Feb 17, 2017 | 07:27 AM
Jegacy1396's Avatar
Default Car cranks turns over but wont start
hi i have a 1992 honda civic dx, recently i bought this and it was running , changed my thermostat needed a new one and my spark plugs looked burned so i got new ones and put them in, after doing that the car couldnt start at all, it cranks but didnt start , so i changed the dizzy cap rotor ignition coil, and even the spark plug wires, as well as the fuel pump, it sounds like it was abouta to start, but didnt, idk what it is thats keeping the car from not starting whether its the ecu since theres a engine light for 19 which is a automatic tranny antilock since it was switched from a auto to manual but it still turned on before that, please i need help with this!!
Old Feb 17, 2017 | 07:28 AM
Jegacy1396's Avatar
Default Re: Car cranks turns over but wont start
also checked my main relay and fuse box and everything was fine
Old Feb 17, 2017 | 08:29 AM
mk378's Avatar
The four little ground wires on the thermostat ground the whole ECU system. Make sure they are really grounded. If the bolts holding the thermostat cover to the housing or the housing to the engine are rusted, there could be poor contact.
Once it is running there is a way to modify ECU to make it work as a manual and not throw code 19.
EcivicG
20
Aug 11, 2008 06:09 PM
chinese buffet
Jul 16, 2006 05:09 AM
Ace of Spades
Feb 28, 2005 06:52 AM
Ace of Spades
Feb 21, 2005 05:14 PM
